350 screamer Posted January 27, 2012 Report Share Posted January 27, 2012 went to start up the shee after i was all done today first few min i swear it was runnin fine, then the left side was cutting out, and it was just runnin on the right, i took off the pipe looked up at the piston and there was a little liquid runnin down the side of the piston, its getting to much fuel, i just changed the jets before i put it all together, im at 280, and the right side sounded fine, its just the left side, i dont get it.... WTF, i checked the spart its getting spark, its either gotta be to much fuel, or not enough air, im thinking pilot jet? to 27.5? maybe my mods are 4mill 5mm long rod +4 timing FMF fattys and silencers .20 over bore shift star and im roughly at 500- 637 ft above sea level Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted January 27, 2012 Report Share Posted January 27, 2012 went to start up the shee after i was all done today first few min i swear it was runnin fine, then the left side was cutting out, and it was just runnin on the right, i took off the pipe looked up at the piston and there was a little liquid runnin down the side of the piston, its getting to much fuel, i just changed the jets before i put it all together, im at 280, and the right side sounded fine, its just the left side, i dont get it.... WTF, i checked the spart its getting spark, its either gotta be to much fuel, or not enough air, im thinking pilot jet? to 27.5? maybe my mods are 4mill 5mm long rod +4 timing FMF fattys and silencers .20 over bore shift star and im roughly at 500- 637 ft above sea level check your harness isn't burning against the exhaust. that's how it started with mine. Quote Link to comment Share on other sites More sharing options...
350 screamer Posted January 27, 2012 Author Report Share Posted January 27, 2012 check your harness isn't burning against the exhaust. that's how it started with mine. that would suck, it wasnt runnin that long before it ocurred either, i dont see how it would hav gotten hot enough to do it but ill start there in the morning Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted January 27, 2012 Report Share Posted January 27, 2012 that would suck, it wasnt runnin that long before it ocurred either, i dont see how it would hav gotten hot enough to do it but ill start there in the morning easy to check. How are you running the gas lines too? start wit as much basic stuff as you can. the oil dripping down is just because it isn't burning. My bike backfired and blew the reeds out when I burnt up the harness. hope you dont have any serious problems Quote Link to comment Share on other sites More sharing options...
350 screamer Posted January 27, 2012 Author Report Share Posted January 27, 2012 easy to check. How are you running the gas lines too? start wit as much basic stuff as you can. the oil dripping down is just because it isn't burning. My bike backfired and blew the reeds out when I burnt up the harness. hope you dont have any serious problems i putted up the street, warmin up you know see how it rode, got on the gas a lil, thats all i know, maybe thats wat did it, i was thinkin reeds to as well least i know this all now im checkin erything big time, its not mayjor, i wouldnt think Quote Link to comment Share on other sites More sharing options...
350 screamer Posted January 27, 2012 Author Report Share Posted January 27, 2012 i putted up the street, warmin up you know see how it rode, got on the gas a lil, thats all i know, maybe thats wat did it, i was thinkin reeds to as well least i know this all now im checkin erything big time, its not mayjor, i wouldnt think i backed out the air/fuel screws 2 turns it sounds like its igniting like it wants to run, im really stumped, Quote Link to comment Share on other sites More sharing options...
Bittner Posted February 1, 2012 Report Share Posted February 1, 2012 (edited) Have you checked to see if the carbs are in sync? I had about the same problem with mine an that's what it turned out to be. See if both the carbs slides are landing at the same time an goin up at the same time when u hit the throttle. There's a couple good videos of how to do it on YouTube. Edited February 1, 2012 by Bittner Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted February 1, 2012 Report Share Posted February 1, 2012 I think part of your problem is your jetting. Mine ran like crap when I first picked it up.....mainly because the previous owner had installed FMF fatties and had not changed the jetting. So my symptoms where it would run.....seemed like it wounded off....kinda off when idling but it was still running alright......and if I wanted to move it I had to feather the shit out of it and really pump the throttle to get it up to anything more than 1/4 throttle. And whenever I let off the throttle from 1/4 throttle it would cut one of the cylinders out. I wasn't sure if it was doing it at idle at first because I hadnt paid that much attention to it at first......then I realized it was also cutting out when returning to idle from a rev up. Hopped on the HQ here and figured out I needed bigger pilots. The FMF fatties like a 27.5 pilot.....go get a set from a dealer or from a sponsor (preferably) and slap em in and let us know! Quote Link to comment Share on other sites More sharing options...
