Fatty420 Posted January 25, 2012 Report Share Posted January 25, 2012 Ok, so heres the story, my buddy has an 04 Banshee, he is trying to sell it to me, but We can't get the damn thing to start, he said it has rebuilt motor and carbs with 0 hours on the rebuild, but he hasn't been able to start it, we tried kick starting it over and over, no luck, we tried push starting it, and it fires right up, then dies, we tried push starting again, fires right up and dies, we tried pull starting it just for a few minutes, same thing, starts up and dies, the gas mix is right, there is gas in it, the spark plug is new and getting spark.. Anyone know where to start?? Oh yeah we also tried closing the air/gas on the carb and then open a half turn , try again, open another half turn, try again, same crap, fires up and dies, and sometimes backfires.. is this even worth my time? the price he was asking was $1500 at first but got him down to $650 if it runs, I really want it to run... Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted January 25, 2012 Report Share Posted January 25, 2012 Sure he won't jack price back up if you get it running ?? Did you set float height? Pull fuel line and see if you have good flow from petcock Quote Link to comment Share on other sites More sharing options...
Motooutcastxxx Posted January 25, 2012 Report Share Posted January 25, 2012 From the sounds of it I would buy it for $650 running or not... put the blunt down for a minute you could probably figure it out. Quote Link to comment Share on other sites More sharing options...
ClayAiken Posted January 25, 2012 Report Share Posted January 25, 2012 Check your Carbs out. Like said above its prob the float height. Quote Link to comment Share on other sites More sharing options...
350 screamer Posted January 26, 2012 Report Share Posted January 26, 2012 Neverrr put the blunt down, thats just..... Disrespectfull to the blunt Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted January 26, 2012 Report Share Posted January 26, 2012 Look between the carbs....is the choke tube there between the carbs? If its not......swoop that thing for like 600 cause it's not running and then throw that tube between the crabs and kick that thing up!!! Quote Link to comment Share on other sites More sharing options...
J-Madd Posted January 26, 2012 Report Share Posted January 26, 2012 Choke tube missing x 2. Quote Link to comment Share on other sites More sharing options...
bigpanther2004 Posted January 26, 2012 Report Share Posted January 26, 2012 Choke tube or make sure the slides are in the right carbs been there done that will it start If you give it full throttle ? Choke tube missing x 2. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted January 26, 2012 Report Share Posted January 26, 2012 Look between the carbs....is the choke tube there between the carbs? If its not......swoop that thing for like 600 cause it's not running and then throw that tube between the crabs and kick that thing up!!! Thats the best option right there. if you dont want it I'll come there and take it cause it wont start. I'll give him 650 no problem Quote Link to comment Share on other sites More sharing options...
