From Mild TO Wild! Posted January 24, 2012 Report Share Posted January 24, 2012 (edited) So I've got it to start for 5 seconds tops. The left had a miss and fuel just streams out the vent on the left carb as well. Im thinking thats the floats. My elevation is 1000 feet. Mild 4 mill with 330 mains and 27.5 pilots. Its piped, tors removed, pod filters and ported Boyesen reed cages with pro reeds. Any ideas to solving my starting issue? It wouldnt start with or without choke either. When it ran i gave it a little throttle and rpms came up then it just died. Thanks for your help. Edited January 24, 2012 by From Mild TO Wild! Quote Link to comment Share on other sites More sharing options...
From Mild TO Wild! Posted January 24, 2012 Author Report Share Posted January 24, 2012 Nvm boys got it figured out. Floats and how the Carb was sitting. Shee runs good Quote Link to comment Share on other sites More sharing options...
04zSpittinKlotz Posted January 24, 2012 Report Share Posted January 24, 2012 Checklist for a running engine.... #1 someone who knows what they are doing #1.a - motor built correctly and in proper specs and tolerances #2 air #3 fuel and in our case oil mixed in #4 compression #5 spark (at the right time helps!) #6 a properly cut head for a 4 mill Just a guess... If anyone else has something to add feel free Quote Link to comment Share on other sites More sharing options...
From Mild TO Wild! Posted January 24, 2012 Author Report Share Posted January 24, 2012 Tnx dill hole. Had the head cut. Its all in spec but thanks. It runs great Quote Link to comment Share on other sites More sharing options...
04zSpittinKlotz Posted January 24, 2012 Report Share Posted January 24, 2012 Tnx dill hole. Had the head cut. Its all in spec but thanks. It runs great Just thought I'd help Quote Link to comment Share on other sites More sharing options...
