willardwright59 Posted January 19, 2012 Report Share Posted January 19, 2012 How do you get the spring off the shock? Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted January 19, 2012 Report Share Posted January 19, 2012 How do you get the spring off the shock? Front? Back? Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted January 20, 2012 Author Report Share Posted January 20, 2012 All 3 Quote Link to comment Share on other sites More sharing options...
Finch Posted January 25, 2012 Report Share Posted January 25, 2012 stock? i know on works just put the valve down and push dont on the spring and pull the retainer out. a friend might come in handy then. Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted January 29, 2012 Report Share Posted January 29, 2012 stock? i know on works just put the valve down and push dont on the spring and pull the retainer out. a friend might come in handy then. Fromts I dont think can be rebuilt. Rears you need a spring compressor and I think the bottom uncrews. I hope someone chimes in with a better answer. Id like to know as well. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted January 29, 2012 Report Share Posted January 29, 2012 I've never wasted much time on the front shocks, but I think once the spring is compressed in a spring compressor, the lower red end unthreads. Not sure though. The rear shock you can get the spring off without a compressor but unthreading both preload nuts all the way, and it should loosen the spring enough to slide out the lower spring retainer. It's shaped like a "c" and just slides out. Good luck getting the preload back where it was, though. I'd use a spring compressor. Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted January 29, 2012 Author Report Share Posted January 29, 2012 I really need a good set of works shocks but just dont have the money now. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted January 29, 2012 Report Share Posted January 29, 2012 the fronts have a c shaped retainer like the rear shock does but its on top instead. these are blaster shocks but you get the idea Quote Link to comment Share on other sites More sharing options...
VR350 Posted January 29, 2012 Report Share Posted January 29, 2012 Actually on the front Banshee shocks the top mount unscrews from the shaft. You compress the spring and there is a place top hold the shaft from turning and you just rotate the top eye. Quote Link to comment Share on other sites More sharing options...
