Which a arms are these?
madbanshee
i must be confused, the bushes look like they wont slide onto the shaft/pin. the bushes i took off dont look like the standard bushings ( see photo below) the pin is the full length of the arm which no room for the bushes to slide in. correct me if im wrong.
are these the bushes im meant to be buying?
http://www.ebay.com.au/itm/NEW-A-arm-Control-arm-bushing-set-Yamaha-Banshee-350-YFZ350-1987-2006-/390358542337?pt=Motors_ATV_Parts_Accessories&hash=item5ae32ea801
I've pushed the pin in so u can see there is no room/gap for the bushes.
Edited by madbanshee
That pic ^^^ shows arm with bushing still in arm. That chunk of shit you show in other pic might be the seal out of dust caps. :cheers:
i had another look today when i got the chance, and yes you are right. they just blended in with the metal that i did not notice them. they are really hard and thought the bushings were metal.
thanks guys.
which bushings should i be looking at? can you guys make recommendations of which ones i should be buying off ebay?
