banshee15 Posted January 18, 2012 Report Share Posted January 18, 2012 its a 87 its got spark but not every kick tested the stator an coil they both passed is it the cdi? or what Quote Link to comment Share on other sites More sharing options...
sstaton1983 Posted January 19, 2012 Report Share Posted January 19, 2012 (edited) not sure what your asking.is it loosing spark on every other engine cycle? look on the flywheel,there should be two tabs 180* apart.if one comes loose it will only spark every other cycle. maybe that helps,unless your saying sometimes it has no spark when you kick it,check terminals,breaks in the wires,or bad ground,dirty contacts on kill switch,bad ig switch.lots can cause intermittent loss of spark. Edited January 19, 2012 by sstaton1983 Quote Link to comment Share on other sites More sharing options...
Boston Posted January 19, 2012 Report Share Posted January 19, 2012 did you by chance have your flywheel off and forget to put the woodruf key back in the slot on the crank shaft? Quote Link to comment Share on other sites More sharing options...
banshee15 Posted January 19, 2012 Author Report Share Posted January 19, 2012 no i put the flywheel key in ill check it an i am asking when i do a spark check i am only getting spark about every 2-5 kicks i tested the stator an coil they seem to be good does this mean bad brain box or flywheel Quote Link to comment Share on other sites More sharing options...
rdzbangshee Posted January 19, 2012 Report Share Posted January 19, 2012 i had this problem with my 87 banshee had water in the stator burnt up the stator and cooked the stator and the wire harness and key switch cost me the about 700$ in parts to fix it . Quote Link to comment Share on other sites More sharing options...
banshee15 Posted January 19, 2012 Author Report Share Posted January 19, 2012 i had this problem with my 87 banshee had water in the stator burnt up the stator and cooked the stator and the wire harness and key switch cost me the about 700$ in parts to fix it . did ur stator an coil all test good? Quote Link to comment Share on other sites More sharing options...
