Jackl Posted January 18, 2012 Report Share Posted January 18, 2012 Ok Ive read all about pistons now I need some feed back on what works wiseco forged more warm up time, Pro-x or stock cast will last longer, ah im confused which to go with now, desert riding and dunes so, I always ran wiseco in my cr 250 way back when but im new to banshees first top end. Ive read many good things about both and bad so is it just preference, any feed back would be appreciated. I just want my shee to be reliable. and run good Thanks. Quote Link to comment Share on other sites More sharing options...
HIDEF Posted January 18, 2012 Report Share Posted January 18, 2012 I'm no expert by any means, My .02 is to go with the Wiseco. That's what i use and i think that most of the ppl here use them in there banshee's. Good Luck ! Quote Link to comment Share on other sites More sharing options...
10milmike Posted January 18, 2012 Report Share Posted January 18, 2012 In my stock Jug dune Banshee, I run Pro X Pistons, I ride Glamis with that bike, have had the same top end for 4 Years now with the pro X, no problems at all. Now in the other bikes I run wiseco, only reason is that they are Big bore bike 73Mm and 78Mm. You will be fine with pro x. Quote Link to comment Share on other sites More sharing options...
Glenyboy Posted January 18, 2012 Report Share Posted January 18, 2012 I've run both pro x and wiseco on my old dirt bikes, both are good. Quote Link to comment Share on other sites More sharing options...
04zSpittinKlotz Posted January 18, 2012 Report Share Posted January 18, 2012 wiseco actually makes pro-x or is their parent co. but i always use wiseco when doing any topend Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 18, 2012 Report Share Posted January 18, 2012 Wiseco. The ONE time I ever used Pro-X they crumbled on me within a week. Never had that happen with Wiseco. Quote Link to comment Share on other sites More sharing options...
papa_smurf49319 Posted January 18, 2012 Report Share Posted January 18, 2012 Wiseco are a forged piston, stocks are cast and a tad heavier. No experience with pro x, wsm, etc. Wisecos have always worked fine for me. Quote Link to comment Share on other sites More sharing options...
blowit Posted January 18, 2012 Report Share Posted January 18, 2012 (edited) For stock to lower power builds with low maint, ProX For heavy hitting builds, Wiseco. X is a casted piston, will be more dense, have more uniform thermal expansion, and higher silica content which equates to longer life but slightly more brittle. Wiseco is forged which IS the best way to go for tough applications because forged bends rather than breaks BUT because they are basically "stretched", their thermal expansion is all over the map, thus causing accelerated wear and require more bore clearance. The biggest problem with cast among Banshee guys is sticking them in a hole that is too big. That will kill them quick. Edited January 18, 2012 by blowit Quote Link to comment Share on other sites More sharing options...
Coupelx Posted January 18, 2012 Report Share Posted January 18, 2012 For stock to lower power builds with low maint, ProX For heavy hitting builds, Wiseco. X is a casted piston, will be more dense, have more uniform thermal expansion, and higher silica content which equates to longer life but slightly more brittle. Wiseco is forged which IS the best way to go for tough applications because forged bends rather than breaks BUT because they are basically "stretched", their thermal expansion is all over the map, thus causing accelerated wear and require more bore clearance. The biggest problem with cast among Banshee guys is sticking them in a hole that is too big. That will kill them quick. +1 ever notice how someone who says their cast piston failed never mentions the circumstances under which it failed OR what the piston to cylinder wall clearance was? Quote Link to comment Share on other sites More sharing options...
