Steering trouble! Stellar and metal techs same trouble? Help!
DwnSouth
set your camber/ caster were it needs to be, i like 1-2 degree's of lean in on top.
set the toe where it needs to be. ( 0 - 1/8" toe in )
then you may have to modify the steering stop to keep the sterring from going over center.. thats what the stop is there for. IF your stop is bent forward you would need to bend it back. weld up the parts that are worn out and install a reinforcement tab. i have done this many times to frames.. its a common problem if the stem dosent hit the stop like it should might be time to make a few phone calls..
i have had to modify stuff like that more then one time to get it to work like i think it should. maybe i'm just to picky or like a bike that i feel is "safe"
Lol! The monkey wrench was just for relieving frustration not using it on my bike!! Lol... this is a stock frame. Bone stock frame just lightened. As far as the stop I already have a nut welded on to limit for my metal techs. The wheels don't turn in sync is the issue. ( I think ) I already can't turn worth a shit. The outside wheel barely turns, the inside wheel turn too much. Both directions same thing. I'm thinking this steering stem isn't made right at the bottom? Holes drilled in wrong spot for the tie rods?? I don't know.... I went get monkey wrench from neighbors yard! 3836a16f.jpg
Check this out... See what I'm sayin
You do want the inside tire to turn at a slightly tighter angle than the outside tire. Think about it, the inside tire is turning on a tighter radius circle than the outside tire. The over-steer is caused by your spindles. A good starting point is that you want the distance from your KPI line at the spindle to the tie rod mounting point to be the same as the distance from the center-line of your steering shaft to the tie-rod mounting point. Increasing or decreasing this distance will effectively speed up or slow down the steering action, and increase or reduce the amount of force required to steer the bike. I would seriously suggest you do some reading on steering geometry before you go cutting and welding anything anywhere on your spindles, or steering stem.
- Jared
