dizzyone Posted January 14, 2012 Report Share Posted January 14, 2012 I've got LSR Carrier Y-1 and i'm trying to find the right size bearings and seals for LSR drag axle 40mm. Does any one have the inside scoop on part numbers and or sizes? Maybe even where I might find em. Quote Link to comment Share on other sites More sharing options...
shakar Posted January 14, 2012 Report Share Posted January 14, 2012 I've got LSR Carrier Y-1 and i'm trying to find the right size bearings and seals for LSR drag axle 40mm. Does any one have the inside scoop on part numbers and or sizes? Maybe even where I might find em. this might be a shot in the dark but...................try lsr racing goodluck Quote Link to comment Share on other sites More sharing options...
camatv Posted January 14, 2012 Report Share Posted January 14, 2012 you will need a correct center crush tube also. are you converting a 35mm carrier? or just replacing bearings? if your just replacing theme measure them out and find what you need. if your converting call LSR OR sell the one you have and buy the correct carrier bet its cheaper than you think Quote Link to comment Share on other sites More sharing options...
dizzyone Posted January 14, 2012 Author Report Share Posted January 14, 2012 you will need a correct center crush tube also. are you converting a 35mm carrier? or just replacing bearings? if your just replacing theme measure them out and find what you need. if your converting call LSR OR sell the one you have and buy the correct carrier bet its cheaper than you think Yea I was hoping to convert it from a 35mm - 40mm. I guess I'll have to call them monday. It currently has the wrong bearings in it. There is about an inch or so gap between the bearings and the crush tube. I'm not sure but that doesn't seem right to me. So I don't know the bearing width. The o.d. is 62mm and i.d. would be 40mm but the width??? Quote Link to comment Share on other sites More sharing options...
BadLarry08 Posted January 15, 2012 Report Share Posted January 15, 2012 Is there supposed to be another row of bearings? Four total? Quote Link to comment Share on other sites More sharing options...
dizzyone Posted January 15, 2012 Author Report Share Posted January 15, 2012 May be I don't know It came with a swinger I purchased. It kinda looks like it though. Quote Link to comment Share on other sites More sharing options...
Broke_Banshee Posted January 17, 2012 Report Share Posted January 17, 2012 i have the bearings and spacers for the 40 and im converting mine to a 35 maybe we can help each other,send me a pm with your number and i will call u tomorrow Quote Link to comment Share on other sites More sharing options...
Starwriter Posted January 17, 2012 Report Share Posted January 17, 2012 It's been a while since i've delt with this, so i don't rember all details, but it may not be possible to convert. You could have 2 single row bearings, 4 single row bearings, or 2 double row bearings. The spacer tube must exactly match the bearing shoulder to shoulder dimension of the carrier. The bearing(s) must be the exact same width when you are converting. If the bearings are a different width it will screw up your chain alignment and other things. Quote Link to comment Share on other sites More sharing options...
