dicedealer702 Posted January 12, 2012 Report Share Posted January 12, 2012 For some reason my axel nut won't stay tight... Any suggestions? Also my rear castle nuts that hold on the hub are always coming lose. The cotter pin keeps them on. Quote Link to comment Share on other sites More sharing options...
TNTS355 Posted January 12, 2012 Report Share Posted January 12, 2012 For some reason my axel nut won't stay tight... Any suggestions? Also my rear castle nuts that hold on the hub are always coming lose. The cotter pin keeps them on. I bought a billet one for like $50 on eBay. Worked well with the two bolts to tighten it. Quote Link to comment Share on other sites More sharing options...
Burke Posted January 12, 2012 Report Share Posted January 12, 2012 loctite... and once you get the axle nuts tight wrap them with electrical tape... and that's exactly what those cotter pins are for. are your splines on the axle messed up at all? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted January 12, 2012 Report Share Posted January 12, 2012 loctite... and once you get the axle nuts tight wrap them with electrical tape... and that's exactly what those cotter pins are for. are your splines on the axle messed up at all? If your splines are wore, you will never keep the hub nuts tight. You can try mounting the hubs with loctite but it will be a bitch to get it apart next time. Quote Link to comment Share on other sites More sharing options...
