too much oil
stroking
927 @ 20:1.... The amount of oil made no affect on HP (actully increased in some areas) until the ratio was greater than 20:1.. If you are running less oil than that and then decide to go to running more oil the bike will be lean because there will be less fuel and opposite if you go from 20:1 to say 100:1 (yes you can run that if you have the right oil) I really like the additional oil in the motor for multiple reasons.
  • 3 weeks later...
Lol if I can run it in a 820 cougar you can run it in anything! Its the best out there imo! O and Tim bond from Titan racing runs is in his 1175cc simatar twin and most of his customers use it also! If you burn your motor up while using this oil you have a bad problem somewhere else! Bottom line try it and you will never go back to what you use to use.
  • 2 weeks later...
