dicedealer702 Posted January 10, 2012 Report Share Posted January 10, 2012 How do u run your water hose with pt mid rev with out touching the pipe . What's your set up? Quote Link to comment Share on other sites More sharing options...
dcalsv02 Posted January 10, 2012 Report Share Posted January 10, 2012 How do u run your water hose with pt mid rev with out touching the pipe . What's your set up? When I was running my mids, using the factory hoses, I never had problems when the hoses would touch the pipes. No burns or anything. I was always worried because they were touching the ppipes, but I never had any issues. You could try putting a bigger diameter radiator hose, zip tied around the actual hose for added protection. Or the factory spring that goes around the hose works fine as long as you don't mid the pipes possibly getting a little marred up where the spring touches the pipes.....hope this helps and makes sense. Quote Link to comment Share on other sites More sharing options...
dicedealer702 Posted January 10, 2012 Author Report Share Posted January 10, 2012 (edited) Thanks bro I will try tO find my stock hose. Edited January 10, 2012 by dicedealer702 Quote Link to comment Share on other sites More sharing options...
