need help on sprockets!
hey i have a 4 mill banshee and want to know what number of sprockets to run.
heres the motor work, tires, andd my weight
4 mill ported
milled head
65 mm pistons
v force 3
stock carbs with 6 in filters
cpi inframes
nology coil
ricks electronics cdi
Tires on rear are skat trak 10 paddle haulers triple buffed 22x11x8
+ 4 swing arm.
i weigh about 120 pounds.
i was told that 14 tooth front sprocket and a 45 in the rear would work great
i wanted to know if this will work or if i need different number of teeth. it has a 13 tooth in the front riqht now and stock in the rear.
i am looking for sprockets i can run on flats and uphill with out having to change them. please help me out thanks
4 mill ported
milled head
65 mm pistons
v force 3
cpi inframes
nology coil
+ 4 swing arm.
Stock rear sprocket should be a 41 tooth so your gearing is 3.1538. The 14/45 gearing will give you a ratio of 3.2142. If you multiply 13 by 3.2142 you will find that you could just put a 42 rear on and have vitually the same ratio without having to buy 2 sprockets and a chain. Your existing chain should have enough slack to let you go 1 bigger in the rear, especially since you have gone 1 smaller in the front.
So you think i should just change the rear one to a 42?
because i thought i would need to change the front one right now because the take off sucks. its alot of rpms but not any take off
I have a 4mil serval and I run 15/41. Have had it in too much sand but everything that I have road it on I love it.
But hows the take off on it in sand?
When I had my ported 350 I ran a 13t in front and 43rear. It was set up perfect for me. I am 100 pounds heavier than you so you could get away with bigger front and rear.
one of my friends had told me to run 14 45 but theres other people here telling me to just run 13 42!
i dont know what to do now
DO the math= 42/13 is 3.23 and 45/14 is 3.21. It is almost the same ratio so performance is going to be the same. You already have the 13 so buy a 42 and try it.
Alright thanks ima try the 42 then
  • 1 month later...
hey man the take off in 2nd gear with that sprocket is much better. i cant keep the front end down though, now i just need to get a longer swing arm.
