banshee wont run,,HELP
421venom
So that little rubber o-ring that sits in the pipe? And no that one lower compression. And the thumb trick is very unreliable. Its nice to find what cylinder in on the compression stroke but that's it. And it'll tell you you have a hole in the piston. Get a gauge. It's a necessity, I think you can borrow them from auto zone.
usually you can its like 40 bucks you can either keep it or come back a month later and get your money back
how can i fix it?
the head? or the jugs?
if its the jugs, you have to bore it to the next size. as long as there mot gouges.
as far as the head i dont know about repair, bbut you can ge a stock one from here for cheap. and you can get a milled one to up the compression a little to bump up a little power.
the jug just one side and will any piston fit if i bore it a next size?
You have to get them done in pairs. You need the exact piston. Lets just say you used the old one after the bore, the gap is to big. The piston will basically flop around till it shatters. To tight is to tight. I think you can figure what happens. You can take them to a shop. They will do it and know what piston you need. If you have the money you can send them out to get ported. Check out hjr or F.A.S.T. I went to HJR and he bored it to the next size, and ported it. Sent me back everything new pistons,rings, and gaskets. If that's not in the budget, just get them bored out.
