banshee wont run,,HELP
421venom
hey guys i need help with my banshee its a 421, it was running awesome and at one race it suddenly stopped,now it has a hard time turning on n when it turns on it dies if i let go off the throttle but the main problem is that it wont run the way it should,,it makes a LOUD back fire from one side it feels very week, i changed the spark plugs and cleaned the carbs but still doing the same thing,any help is appreciated
Go buy yourself a compression tester. They aren't to expensive. Screw it in where your spark plug goes and kick the bike over till the needle stops moving. If you don't want to buy on you can put your thumb over the spark plug hole on the good and bad side and look for the difference. Might be a broken skirt on piston if compression is low.
thanx i will try it, if i put my thumb should i feel something?
