cce12 Posted January 2, 2012 Report Share Posted January 2, 2012 How much time does an override tran help shave off?? Iam trying to get my 4mil stk cyl bike into the 6s before building a cub. This is on asphalt 1/8, currenty running 7.5s 60ft 1.63 330 ft 4.80 with a 210lbs rider on race gas.. things Iam going to add cause I need them for the cub anyways. Override 1-5,straight cut 2.68 ,lockout and 39pwks. Iam wanna try and do this without alky. Quote Link to comment Share on other sites More sharing options...
Phelps Posted January 2, 2012 Report Share Posted January 2, 2012 i would say 1-3 ft of non power transfer between shifts depending on how fast you are... could = up to .3 pretty easy in a 1/8 mile "solely a guess" but if all you do is drag race there is nothing better than a override Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted January 2, 2012 Report Share Posted January 2, 2012 You will gain so much time you will go back in time! Hold On! Quote Link to comment Share on other sites More sharing options...
kthurm Posted January 2, 2012 Report Share Posted January 2, 2012 I wouldn't drag without one its night and day Quote Link to comment Share on other sites More sharing options...
cce12 Posted January 3, 2012 Author Report Share Posted January 3, 2012 .3 tenths and a jockey might get it done.. Thx again Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted January 3, 2012 Report Share Posted January 3, 2012 the trans will help for sure.... but I would work on that 60ft time..... guys are seeing 1.2-1.3 sec 60 ft times on concrete...... Quote Link to comment Share on other sites More sharing options...
cce12 Posted January 4, 2012 Author Report Share Posted January 4, 2012 Drag port stk cylinders I did myself. Mull head, 35pwk, shearer off 10+ swingarm,+7 timing A.R 19x10x8.. Stk trans. 1/8 mile 86mph could get a little more with different gearing just can't get out the 1.6s in the 60ft.. Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted January 4, 2012 Report Share Posted January 4, 2012 wheelie bar would help and adding a lock up would help too... then ya could set your clutch up to slip off the line and then have the lock up lock the clutch up so it quits slipping after the launch.... this will greatly improve your 60ft times on concrete. Quote Link to comment Share on other sites More sharing options...
cce12 Posted January 4, 2012 Author Report Share Posted January 4, 2012 86 at the 1/8 that's max out with 15/40 if i use 15/38 it will pick up a little.. Tire psi is at 4 pounds and depending how gd the track is it either spins a bit or wheelies. I tried some 20 a.r but the was to much tire for this motor. My goal is just to run 6.9s with this. The override/lockout and getting the 60ft into the 1.5s I think might get it done.. Next motor will be a 10 mil cub. I won't have to try that hard to run in the 6's with that:. Quote Link to comment Share on other sites More sharing options...
