BAMF87 Posted December 29, 2011 Report Share Posted December 29, 2011 Yesterday I touched one of the plug wires while it was at idle and I got shocked. I'm assuming I need new wires and boots but can I replace just the wires and boots or do I need a new coil and wires? Either route what brands are good and who has the best prices? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 29, 2011 Report Share Posted December 29, 2011 I bet that woke you up, but you can get just the wires. Go with factory if you have a factory ignition system. Quote Link to comment Share on other sites More sharing options...
ginger Posted December 29, 2011 Report Share Posted December 29, 2011 I bet that woke you up, but you can get just the wires. Go with factory if you have a factory ignition system. its supposed to do that, they arent made to protect you. That is fine, if you go to a car, or a go kart, they will shock you while running as well. You dont have anything to fix. Quote Link to comment Share on other sites More sharing options...
NetBSD Posted December 29, 2011 Report Share Posted December 29, 2011 its supposed to do that, they arent made to protect you. That is fine, if you go to a car, or a go kart, they will shock you while running as well. You dont have anything to fix. dont listen to this guy, you have to replace the wires. chances are the insulation is cracked and you will get weak spark from it arcing off the frame Quote Link to comment Share on other sites More sharing options...
ginger Posted December 29, 2011 Report Share Posted December 29, 2011 dont listen to this guy, you have to replace the wires. chances are the insulation is cracked and you will get weak spark from it arcing off the frame what ever you say, when you blow the money on new wires, try grabbing them and let me know when you get shocked Quote Link to comment Share on other sites More sharing options...
NetBSD Posted December 29, 2011 Report Share Posted December 29, 2011 what ever you say, when you blow the money on new wires, try grabbing them and let me know when you get shocked come and grab any wire on any of my multiple cars/bikes and i bet you dont get shocked Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 29, 2011 Report Share Posted December 29, 2011 (edited) what ever you say, when you blow the money on new wires, try grabbing them and let me know when you get shocked Do you get shocked on all your wires? Edited December 29, 2011 by sheerider11 Quote Link to comment Share on other sites More sharing options...
My03banshee Posted December 30, 2011 Report Share Posted December 30, 2011 lol why the hell Should you be able to be shocked when you grab a plug wire? The whole point of the wire is to transfer the current from the coil to the plug and NOT to let to let it leak out anywhere in between, bottom line is if you get shocked then they're dry rotted or leaking somehow. If they're "supposed to" leak then wires should be ran nowhere near each other nor other engine parts (which is grounded out) and on a car engine there's no way you can have the wires in certain spots where they don't touch something else or close to it. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 30, 2011 Report Share Posted December 30, 2011 You should NOT be getting shocked by touching the rubber coating of the plug wire. The rubber is there for a reason. That's to protect the wire from touching anything metal. Honestly, it will be a lot cheaper and easier to replace the whole coil. I have more peace of mind knowing it's put together correctly that way. Hit up NYUK here on BansheeHQ. He probably has a few coils laying around. Quote Link to comment Share on other sites More sharing options...
thomas h. Posted December 30, 2011 Report Share Posted December 30, 2011 Replace the coil Yes it can run but it is showing you a warning If you want replace the caps and install 3 layers of shrink warp over the wires that may be ok repair but I would get new FYI Quote Link to comment Share on other sites More sharing options...
BAMF87 Posted December 30, 2011 Author Report Share Posted December 30, 2011 Ok thanks guys I'll see what I can afford. Any idea where to look? Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted December 30, 2011 Report Share Posted December 30, 2011 Check out arctic cat coils too, they fit the stock location and have a little hotter output if you're looking for a cheap upgrade. - Jared Quote Link to comment Share on other sites More sharing options...
