jonvia Posted December 26, 2011 Report Share Posted December 26, 2011 my damn carb on my left side is leaking gas out of the drain hose. the float is free moving, the splash guard is in the correct place. the jets are tight... what is causing it to still leak?? its never done this before... i need help. its very aggravating. the machine is not even running when it starts to leak... what is this? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted December 27, 2011 Report Share Posted December 27, 2011 (edited) Take the float valve needle seat out. Take a Q-tip with tooth paste on it an polish the needle seat, do it several times until there is no dark crap on Q-tip. Then clean toothpaste off. Also inspect needle valve closely, should be no grooves or cracks. Edited December 27, 2011 by Larry's Shee Quote Link to comment Share on other sites More sharing options...
dillbilly Posted January 2, 2012 Report Share Posted January 2, 2012 Never tried the tooth paiste. Got to give that a try. Anyway prob needle seat Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted January 3, 2012 Report Share Posted January 3, 2012 Would think it would have to be the white kind, not gel. I did it to a carb and was amazed at crap that was on Q, and seat looked new. Imagine Mothers mag, simichrome, or brasso would work too, anything to clean and polish it. Quote Link to comment Share on other sites More sharing options...
