Jetting issues
thomas h.
So with the long needle in leanest clip the one (with 6 clips maybe call a dyno jet needle from alba no markings )the power was flat then mid to top pulls good.
With the stock needle mid clip it goes then dies abit then pulls good.
I think it needes more fuel
Stock carbs 310 m 27.5 stock needles
Toomey t4 k&n no port. Clean carbs ok plugs
why would you try the leanest setting,longer needles sit in the jet more so try 4th clip,how does the plug look
Ok now just tryed the short stock needle on Max rich clip
And it seemed to load up then go hard. Next gear alittle less. But you go slow first gear and it seemed to load up like to much fuel. The best so far might be long needle and 2 nd to rich.
Do most banshees have a lag at the bottom
I still want to get ride of the bog between low to mid
Any in put?
