banshee9090 Posted December 23, 2011 Report Share Posted December 23, 2011 hi guys, i drag 1st up to 6th gear give it full throttle fine ,but if i drag with 2th gear give it full throttle start fine and the front of the bike start to go up but also start to bog then go fine again up 6th gear , may i know what is the problem way she is bogging with 2th gear with the front of the bike is up , she is not doing bog with 1th gear i want to safe time if you can help me hear. pleas note i was using same setup with old 4mil shee and not boging in the 2th gear also there is pic. of last spark plugs . Right Left Quote Link to comment Share on other sites More sharing options...
volcrano Posted December 23, 2011 Report Share Posted December 23, 2011 the pictures are somewhat hard to see. it looks like the first plug pic is slightly lean, esp compared to the one under it. like i said the pics are hard to see so they might be okay. can you take a pic with both of them next to each other in same pic. have you checked for air leaks?? Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted December 25, 2011 Report Share Posted December 25, 2011 If they look diffrent you can have a couple of causes ,dirty carbs,ignition system problem or air leak Quote Link to comment Share on other sites More sharing options...
banshee9090 Posted December 25, 2011 Author Report Share Posted December 25, 2011 If they look diffrent you can have a couple of causes ,dirty carbs,ignition system problem or air leak well right side is light brown and when i start the the engine in idle and i put my hand at the exhaust outlet the pressure looks weak not the same with left side pressure but after it is Warming up every thing is ok , pleas take note crank pressure both side 158psi, i did air leak test before i run it , will go to another tow causes, thanks sleeper06 for the nice advice. Quote Link to comment Share on other sites More sharing options...
banshee9090 Posted December 25, 2011 Author Report Share Posted December 25, 2011 the pictures are somewhat hard to see. it looks like the first plug pic is slightly lean, esp compared to the one under it. like i said the pics are hard to see so they might be okay. can you take a pic with both of them next to each other in same pic. have you checked for air leaks?? thanks man i will shop later , i m thinking about tow thinks now first is the gear is not shifting to the 3th gear most of the time with full throttle at the dune i m dismantling the clutch cover and have look on it the sacand is bog after the front of the bike is up with 2th gear, i will go to 13 sprocket and see what will happen. thanks for the input man. Quote Link to comment Share on other sites More sharing options...
banshee9090 Posted December 30, 2011 Author Report Share Posted December 30, 2011 thanks guys problem solved , i gust clean carbs. went to 320 on the main jet , Quote Link to comment Share on other sites More sharing options...
