Impeller Question?
volvo63'
I am currently in the process of rebuilding my banshee. It just blew up so I removed the impeller cover and found that the impeller was not the problem but it was pretty well wore. So I was wondering what impeller to get.
Should I go pro design or chariot, and if chariot, high flow or ultra flow??
new stock.
Yea don't do the stock impeller if you can help it not to shit on what everyone else said cause brand new they are the same but over time the grade plastic yamaha uses that shit turns into a very soft plastic not much harder than cardboard so of you swapping and have to pay spend the extra 10 bucks get the billet, also go mull or chariot they use the stock shaft which modquad and others don't and their shaft is slightly bigger and can cause issues turning just my .02 cents
chariots impeller does not uses the stock shaft.
