sand in my crank...need help please
monstermike
So I just ordered some ported jugs from Kevin Herr and I'm stoked. Had my 89 for about 2 months. First quad I've ever had. ReBuilt a few car motors that's my background. And enjoy doing stuff myself.
Any way.
I cleaned around the cylinders with a rag , brake cleaner, and air from compressor. Took cool head off. Then when I took the left cylinder off , some sand from the between the two jugs fell on the crank. Ahhhhhhhhhh!!!!!!!!""
I currently have broken wrist so working on it is hard with a cast....
Hope idont have to tear bottom end apart
Being a newb and cripple
Once I assymble it can I run it for 10 sec
Oil change
Run for 30sec
Oil change
Over
and over like 5 or 6 times.
Sand is one of those things that can demolish a motor in a short period of time... If it were me, and this was a brand new motor, I wouldn't risk it... You could probably pull the other cyl off, fill the cases with gas or I've heard you can use diesel, turn the crank over a few times by hand, and dump it out... do that a few times and I think you'd be okay...
Then again, all the pre-lubed parts on your crank would no-longer be lubed...
i wouldnt trust the gas/diesel to clean all the sand out, to many places for it to hide. im not saying it wouldnt clean it out but i just wouldnt trust it, wipe out the mains and you got alot more money to toss into that thing
No, it's not going to be perfect, but that's why I said fill it up, and turn it over (spin the crank), and repeat it a few times until it all comes out.
I mean, let's face it, 95% of us who put together motors do-so in our garages, there is dust, dirt, and other shit that probably falls in our motors without us knowing. Truthfully, the BEST way is to tear the motor completely down, and clean everything in a solvent tank, but short of that, the diesel thing I think would be the most thorough thing that you could do.
Oil change
Run for 30sec
Oil change
Over
Mike, reading that prompted me to give you a little heads up; the crankcase is separate from the gearcase.
If you are gonna flush the crankcase then do it when the cylinders are removed, through the same opening that the dirt fell in. Turn the motor upside down to flush out.
Don't put diesel into the opening where the dipstick goes... I would just split the cases if it were me.
good luck and happy holidays
LOL. I hear u.....ikinda figured it out.....
....all I know bout the bottom end is through research
but thanks dude. That'd be pretty bad to drop in some diesel. In the trans
I think Ima flush it a few times
I knoow its half ass but i think it'll be allright.
I wanted to wait til summer to do a complete. Teardown
Happpy holidays to you and everybody else on here
any more advice toowards not spplitting cases is cool too. :)
i would use gas or mixed gas imo instead of diesel, i mean thats what is in there normally and wouldnt dry out the bearings. even if you split the cases it would still be hard to make sure you got it all outta the bearings, id flush it probably 10 times if it were me. i wouldnt rotate the crank the first few times just try to shake that heavy bassterd around and dump it, then rotate it and dump. also after you feel like your done rotate the crank to see if you can feel any "grindage" lol and if you still have the other jug on id leave it on for the douching :headbang: would be easier to rotate the crank without worrying anout the other rod floppin around
The problem with using mixed gas is that you will still have oil in the crankcase that will cause the sand to stick the cases, crank, bearings and seals. If he really does not want to split the cases, I would wash it out with clean solvent and/or alcohol, then blow it dry with air. Once you are satisfied that it is clean and it turns over smoothly, I would dump 2 stroke oil in the crankcase, enough to fill it about 1/2 way and then turn the crank to make sure it is all lubed. After letting it soak for awhile dump out the oil and you should be fine.
I would split the cases, you're only talking 20 nuts and bolts. Try to find a parts washer you can use or pay to have it cleaned. One grain of sand will destroy a bearing. Lots of difference between dust in the air and sand, 80 grit vs 2500. Please do not use gas as a cleaning solvent, you are inviting, no begging, for a disaster to fuck you up :shootself::shootself::shootself::cry: . And I'm not talking about a stupid motor. Use diesel or kerosene only.
