BANSHEE parts! ALL PARTS ARE SOLD BESIDES THE STATOR
I have a few Banshee parts for sale. Please reply with any questions or if you would like more pictures. I have many more pics than what is posted. All parts would be packaged extremely well to ensure there condition.thanks!!
1)A set of Keihin 34mm PJ carbs. They are both complete with jets and airfilters. They look and work excellent. They have no damage or wear. One bowl has the center nut welded on-see pictures. The filters are in decent shape but still work fine. SOLD
2)Toomey T-5 chrome pipes with silencers. The pipes have some very small dings and a little minor rust. They look good when on the bike though. The silencers have some very minor dings. SOLD
3)A set of V-Force 3 reeds. These are complete and in excellent condition. They were barely used and look like new. One cage was damaged and was repaired-see pictures. They still work like new. SOLD
4)+4 adjustable rear axle. It's in good condition and straight. SOLD
5)Ohlins rear shock. The shocks is very clean and in excellent shape. It was used very little and shows almost no signs of use. It looks and works like new! SOLD
6)LSR +2 +1 front a-arms. The arms are in good condition with no dents or bends. One ball joint is brand new..the other are in good shape. Also includes longer tie-rods w/ends. The powercoating has worn off in some areas but otherwise the parts are in great shape. SOLD
7)Stock OEM rear axle. Good condition and straight. $40+actual shipping.
8)Oem ported+bored cylinders. They have mid/high range porting. Not sure who did the work though. They had perfect compression but show some very minor wear grooves from the rings. SOLD
9)Hot Rods +4mm crankshaft. Trued and welded. Has about 50 hours of total use. Its' complete minus the wrist pin bearings...unless I find them before the sale. SOLD
10)Complete Ricky Stator stator and bracket. Parts are in excellent shape. The stator was barely used..the wires and plugs are like new. $65 shipped(mag is SOLD)
11)Bottom end cases...includes top and bottom. Both parts are in great shape with no repairs or major damage. The gasket surfaces are perfect. They have no stripped threads. They just need a little cleaning on the outside. SOLD
12)Complete transmission(stock oem) with gears, shafts, forks shiftstar hardware and etc. Everything in the tranny besides the clutch and kick-start gears is included. SOLD
13)Hinson HD Billet clutch basket with buttons. Parts are excellent shape with little use. SOLD
14)Pro-Design Cool Head. Complete with all o-rings and head studs. Also includes 2 sets of domes(18cc+19CC small bore). All the parts are in great condition. Nothing is damaged or worn. SOLD
15)Pro-Design alloy intakes w/alloy boost bottle and reed spacers. The intakes have flanges for 33-35mm carbs. The parts are very clean and in excellent shape. SOLD
  • Replies 42
  • Created
  • Last Reply
Top Posters In This Topic
Pictures of the adjustable rear axle and LSR a-arms. There is a brand new ball joint that is included with the a-arms but not pictured. The axle has some very minor surface rust on the chrome in a couple areas, it should come off with steel wool wd40. The castle nuts(axle) show a little wear but can still be used saftely. The a-arms are in good shape besides some of the powercoating is chipping on the lower arms.
