Banshee not running correctly
Mike.
My 2008 banshee doesnt seem to be running 100%
It has paul turner front pipes with fat boy rear cans, i was also told when i bought it that the jets were changed in the carbs(unknown size) and it is also supposed to have aftermarket reed valves.
Standard airbox and filter.
Standard carb size
My question is
The quad runs fine on idle but when i accelerate it floods itself before it comes into the power band and then it drives perfect.
How can i get it to stop flooding itself before it comes into the power band? It makes it very hard to drive at the moment because it just doesnt have the power to pull me around when its out of the power band due to the flooding.
Thanks
Edited by Mike.
HEY, Welcome :cheers:
Going to need more info on your set-up. PT mid or hi? Any porting? Air box lid on or not? Have you dissasembled carbs for cleaning? Set float height? Would really help to know pilot and main jet, needle and clip posistion, turns on air screw. :cheers:
I dont know much about carb set ups to be honest.
Air box lid is on.
I havnt touched the carbs yet as i was hoping to get an idea of what is wrong here first and then go from there.
How do i know what size jets i have?
And what is "Pt mid or hi" and "needle and clip position"
I really dont know anything about carbs so be patient haha
Thanks for the help
If you can take the bowl off your carb the removable brass parts are the jets look for the stamped numbers.
The pt is Paul tuner and they will say what model mid range design or hi range design
If you take apart your carb and slide, the needle is there. Please tell us what position the. Clip is in.
  • 4 weeks later...
