Bkm2006 Posted December 17, 2011 Report Share Posted December 17, 2011 bought a brand new tusk axle to go with my new steller swing arm.. my ? is do i need loctite with a pinch bolt? this is tusk's pinch bolt that came with the new axle... i wont it to hold just a pain in the ass to ever take off with the loctite.. i played hell getting the stock one off, finally just ended up cutting the stock one off stock axle. Quote Link to comment Share on other sites More sharing options...
vifferman Posted December 17, 2011 Report Share Posted December 17, 2011 Loctite EVERYTHING! Not with the perm stuff (red?) but with the temp (blue?). How often are you going to be removing your axle? Next to never. If you are having a hard time removing the axle nut try a little heat from a torch, and/or soaking it with WD-40 or similiar. Just don't use them at the same time. Quote Link to comment Share on other sites More sharing options...
dillbilly Posted January 2, 2012 Report Share Posted January 2, 2012 do not use the red x2. I personally dont loctite axle do to replacing axle bearings. Those nuts are a sob sometimes. Quote Link to comment Share on other sites More sharing options...
ticktock Posted January 2, 2012 Report Share Posted January 2, 2012 Loctite is amazing. It is a Harley owners best friend as every bolt will vibrate loose without it! I personally do Blue on everything outside the motor and inside the motor I use red. Loctite will also help seal all the threads so the bolts will not rust in blind holes. Adam Quote Link to comment Share on other sites More sharing options...
dunebuggy09 Posted January 2, 2012 Report Share Posted January 2, 2012 personally i loctite mostly every bolt with the blue stuff....i rarely use red because it requires heat to get it off Quote Link to comment Share on other sites More sharing options...
