Banshee Chad Posted December 16, 2011 Report Share Posted December 16, 2011 (edited) Finally scored a set of front sand tires... Got scat track smooth buffs on blue labels for $50... Almost new. Now I just need the snow to melt so I can test em. Never had front sand tires before. Also got a set of sand tires unlimited razor backs on some blue labels from a friend for free..for zilla wheels so I gotta drill em out.. unless someone wants to trade? Need a second set for my wires trailblazer, which has same pattern as banshee. Edited December 16, 2011 by Banshee Chad Quote Link to comment Share on other sites More sharing options...
jasons Posted December 16, 2011 Report Share Posted December 16, 2011 Finally scored a set of front sand tires... Got scat track smooth buffs on blue labels for $50... Almost new. Now I just need the snow to melt so I can test em. Never had front sand tires before. Also got a set of sand tires unlimited razor backs on some blue labels from a friend for free..for zilla wheels so I gotta drill em out.. unless someone wants to trade? Need a second set for my wires trailblazer, which has same pattern as banshee. IMO, the only thing good about the smooth buffs is if you just want to do straight line running. if your duning i would want a rib cause it acts like a rudder on a boat going through the water. Now for your second set of tires i dont know if there front or rear but i know that STU makes a front razor back and there a awesome tire and i would love to have another set. i have a set of smooth buffs i dont need or want on douglas rims. Quote Link to comment Share on other sites More sharing options...
06specialedition Posted December 16, 2011 Report Share Posted December 16, 2011 I swapped out my front mow-hawks for some smoothies....I like them IMO front tires make a world of difference. Quote Link to comment Share on other sites More sharing options...
Banshee Chad Posted December 17, 2011 Author Report Share Posted December 17, 2011 I swapped out my front mow-hawks for some smoothies....I like them IMO front tires make a world of difference. That's what I hear... Quote Link to comment Share on other sites More sharing options...
jasons Posted December 17, 2011 Report Share Posted December 17, 2011 copied this from STU website. smoothies suck for duning period again JMO, they dont help you turn, they just dig and push. if you just wanna drag by all means run a smoothie. Sand is to ATV's as air is to a plane and water to a boat. It all works the same. So, create a bigger tire and more footprint and you get more floatation. Sand moves away when you push off it and it moves around when you apply pressure to it. So, it follows that a front sand tire should turn through an unstable medium, like sand, just as rudders do on planes and boats. We gave this tire a biased rudder. Quote Link to comment Share on other sites More sharing options...
Banshee Chad Posted December 17, 2011 Author Report Share Posted December 17, 2011 copied this from STU website. smoothies suck for duning period again JMO, they dont help you turn, they just dig and push. if you just wanna drag by all means run a smoothie. Sand is to ATV's as air is to a plane and water to a boat. It all works the same. So, create a bigger tire and more footprint and you get more floatation. Sand moves away when you push off it and it moves around when you apply pressure to it. So, it follows that a front sand tire should turn through an unstable medium, like sand, just as rudders do on planes and boats. We gave this tire a biased rudder. Ya, the logic is there.... But I got lots of friends that love their smoothness over any ribbed. Quote Link to comment Share on other sites More sharing options...
jayzx10r Posted December 18, 2011 Report Share Posted December 18, 2011 I run the STU razors....best tire out there period!! Baldies are great when all you're doing is straight line dragging but they suck hind titty for turning. The STU's are so light that people trip when I hand one to them off the bike..... Quote Link to comment Share on other sites More sharing options...
Hotrod65 Posted December 18, 2011 Report Share Posted December 18, 2011 I run the STU razors....best tire out there period!! Baldies are great when all you're doing is straight line dragging but they suck hind titty for turning. The STU's are so light that people trip when I hand one to them off the bike..... Jayzx how would you compare your STU razors to the Skat-trac Mohawks turning wise? What size of rim/tire are you running? I'm needing front sand tires and I'm using haulers 22 x 11 x 8" on the back with 12 paddles. I was considering running either a 21 x 7 x 10 or a 23 x 8 x 11 Mohawks on the front, but was not sure which would work best with the 22" haulers since I am "NEW" to Banshees? Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted December 21, 2011 Report Share Posted December 21, 2011 I'm going to agree with Jay on this one. Guys, check out my sig pic sand tires.. that center rib cutting thru sand! Love how these tires just surf on sand.. Tires are softer with more cushion. My mohawks dig into the sand instead of surfing on it. Quote Link to comment Share on other sites More sharing options...
Banshee Chad Posted December 22, 2011 Author Report Share Posted December 22, 2011 Ya, ill try both I suppose. Either is better than the dirt tires.. those smooth buffs are just so light Quote Link to comment Share on other sites More sharing options...
monstermike Posted December 22, 2011 Report Share Posted December 22, 2011 Where'd you. Get em fir 50$ Chad? Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted December 22, 2011 Report Share Posted December 22, 2011 You'll be fine with the smoothies for that average dune ride. You're going to need that center rib if you wanna play hard tho. You won't care how light the wheels are when you're 15 miles into glamis trying to carve some 4th gear bowls. Quote Link to comment Share on other sites More sharing options...
Banshee Chad Posted December 27, 2011 Author Report Share Posted December 27, 2011 Found em on local classifieds ksl.com. Ya, ill report back soon as I get a chance to try em out. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted December 27, 2011 Report Share Posted December 27, 2011 I run the STU razors....best tire out there period!! Baldies are great when all you're doing is straight line dragging but they suck hind titty for turning. The STU's are so light that people trip when I hand one to them off the bike..... The ITP Sand Stars double rib will out cut a Razor back any day. I switched from Razors to Sand Stars and my bike turns WAY BETTER and goes exactly where I point it. They might weigh a little more but are far more durable and less money than Razors. Quote Link to comment Share on other sites More sharing options...
Banshee Chad Posted December 27, 2011 Author Report Share Posted December 27, 2011 The ITP Sand Stars double rib will out cut a Razor back any day. I switched from Razors to Sand Stars and my bike turns WAY BETTER and goes exactly where I point it. They might weigh a little more but are far more durable and less money than Razors. Nobbies turn awesome.. they are just heavier. I think its a matter of finding right tire for bike/rider. The more ridges or nobbs you have of course the better it will turn. But is the drag worth it? I know a lot of people that run the buffs and love them. Guess well see. Quote Link to comment Share on other sites More sharing options...
