rnegv Posted December 16, 2011 Report Share Posted December 16, 2011 actually it's easier Quote Link to comment Share on other sites More sharing options...
camatv Posted December 16, 2011 Report Share Posted December 16, 2011 here is my take on a stiff throttle.. clean the entire thumb throttle assembly, lube the thumb shaft. make sure the housing is sealed. lube the cable with a proper cable lubber dont use chain lube use either cable lube OR cheapo spray lube from walmart.. ( yes i said it). clean the carbs and the slides up clean the area where the slide goes extra well. check the slides for being either chrome plated or std non plated, as both were avaialble non chrome plated will grove out and stick realy bad. if after that you still think the throttle is to stiff sell the bike and go play video games. my wife's turdwagon has twin 38mm lectrons and she never bitches about the pull. Quote Link to comment Share on other sites More sharing options...
Schweet97Z Posted December 16, 2011 Report Share Posted December 16, 2011 What about the Chariot Thumb Throttle? http://www.ebay.com/itm/280724648948?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Quote Link to comment Share on other sites More sharing options...
wfobasheeboy Posted December 16, 2011 Report Share Posted December 16, 2011 Do not cut the spring. Just get some spring from F.A.S.T & call it good & stop bitching. LOL I good a set of spring from F.A.S.T & they work great! Quote Link to comment Share on other sites More sharing options...
medley Posted December 16, 2011 Author Report Share Posted December 16, 2011 here is my take on a stiff throttle.. clean the entire thumb throttle assembly, lube the thumb shaft. make sure the housing is sealed. lube the cable with a proper cable lubber dont use chain lube use either cable lube OR cheapo spray lube from walmart.. ( yes i said it). clean the carbs and the slides up clean the area where the slide goes extra well. check the slides for being either chrome plated or std non plated, as both were avaialble non chrome plated will grove out and stick realy bad. if after that you still think the throttle is to stiff sell the bike and go play video games. my wife's turdwagon has twin 38mm lectrons and she never bitches about the pull. i have been riding for 20yrs and know its not supposed to be this stiff. i know the springs are stiffer in these than the stock ones. i am just looking for a way too make it easier. i have had the carbs apart 20x's and the slides are fine and there chrome. Quote Link to comment Share on other sites More sharing options...
medley Posted December 16, 2011 Author Report Share Posted December 16, 2011 Do not cut the spring. Just get some spring from F.A.S.T & call it good & stop bitching. LOL I good a set of spring from F.A.S.T & they work great! far from bitching. haha Quote Link to comment Share on other sites More sharing options...
camatv Posted December 17, 2011 Report Share Posted December 17, 2011 how is the calbe routed? is it in the right spot? even a new cable should be lubbed. lube goes a long way in making things slippy slide when they dont really want to Quote Link to comment Share on other sites More sharing options...
medley Posted December 17, 2011 Author Report Share Posted December 17, 2011 its ran the right way. there is no binding or anything. i will try some lube. Quote Link to comment Share on other sites More sharing options...
My03banshee Posted December 18, 2011 Report Share Posted December 18, 2011 how is the calbe routed? is it in the right spot? even a new cable should be lubbed. lube goes a long way in making things slippy slide when they dont really want to I was gonna say check the routing too, the routing goes a long way as far as how easy and hard it can be. I once had a moped that had a hard throttle, rerouted it and was 10x easier, same with clutch cable on my mustang, but I vote for the easier carb springs. Quote Link to comment Share on other sites More sharing options...
