Jetting Help
NJ2STROKE
I just got the bike running had an issue with the rev limiter. Trying to break the motor in. It is fine at 1/2 throttle in 1-3, when i go to 3/4 in 3rd it starts stuttering and then gets ready to shut down. if i take it 4th at low RPM's it will shut off. I am at about 36 ft ASL, and it is between 50-70 degrees, but I'm in VA so the temp changes everyday. I think the carb came with a 160 main. Looking for some insite on how far up to take it, it just seems like im not getting enough gas. HELP PLEASE!!!!
41mm pwks on gas probably high 160s to high 170s. I would try some 175s and chop the plugs and see that the smoke ring looks like. If you dont mind buying jets start at maybe 180 and go down.
Thanx.. I ordered two kits 160,162,165,168, 170 and 170,172,175,178,180. I hope this works. I planned on going big and then going down. Rather be rich than lean. Been working on this bike for a while.. just ready to ride. the jets should be in mon so we will see. Thanx
