brand new owner question about mix ratio
remi_357
927 is not recomended at all for colder weather. it can seperate in the tank as you ride.. plus in a gas motor i really dont like that oil anyways its so dam gooey and shit.. carbons up the exhaust and pistons like crazy. ON gas motors
32-1 work great
32-1 work great
+1 i used to run it all the time until i got sick of the splooge that oozes out of the exhaust and connections. I run klotz super techniplate at 32-1 now in all weather. The premix is your engine only source of lubrication. dont be cheap and try to run less oil to save money. if this is a concern you need to buy a 4poker.
It may also be worth mentioning that there is power to be had with a richer oil mix.
Ran 927 for 9 years in by banshee 2 different motors. Just tore the topend off my most recent build 5 years and very little carbon on the piston. I run 40:1. I guess if you run 32 and your jetting is a little off or you lug it a lot it could build up. Who knows. Also im in NE Ohio and Ive rode it in 7 Degree days with NO problems. Never blown it up never even had low enough compression to need a rebuild. Just rebuild to change things up. 4 years on stock top end and 5 on a FAST 4 mill. That being said Klotz what I would run if I didnt run 927.
Fast, now that's customer service. Do you happen to carry the r-50?
No but i have everything else... Give me a call Sat. as im open until noon and can bring it to Topeka sat afternoon.
2004LEBanshee, IF you have 5 yrs on that top end it prollys needs freshened up. Send it to me and i will update the porting if need be with the lastest and greatest!
