New fast motor need help fouling plugs
Bkm2006
Ok so just picked up my motor a few days ago. Mods are in sig. It will kick over fine and idle for a min, the. Foul left cylinder plug. Stock carbs 360 main jet. Toomey needle down one notch from center, pulls needle up (rich)..... And 27.5 p.... Should I go down a size on main jet? Plug looks black on left side when I take it out.
Try a 340 main and put the clip in the middle postion. That works for mine and we have about the same mods... What does the other plug look like? I have dual K&n air filters also. Your mains seem a little high what is your elevation I'm at sea level. Can you rev it at all? It could be a jet stopped up. I really think your mains or to big unless the other side looks fine then I would say clean the carb and jets out..
Edited by gh2010ism
Wtf wow took the carbs apart for the 100th time float was sticking. And I just rebuilt the carbs. All is good she idles like a champ now I get to use my f.a.s.t carb sync
Good deal man glad to see you got it working!!! You want to jet your bike so your plug is a brown color like in the pic.
Edited by gh2010ism
