UPbansheeRacer Posted December 9, 2011 Report Share Posted December 9, 2011 looking to upgrade to a better set of shocks on the front of my banshee these locks look cool but how are they? http://www.ebay.com/itm/15-3-4-400mm-Front-Shock-Absorbers-Yamaha-YFZ-450-Raptor-700-660-Banshee-ATV-/180770569794?pt=Motors_ATV_Parts_Accessories&vxp=mtr&hash=item2a16c3fe42 Quote Link to comment Share on other sites More sharing options...
Dicklez Posted December 9, 2011 Report Share Posted December 9, 2011 There so good they dont even have a name. Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted December 9, 2011 Report Share Posted December 9, 2011 Id prob rock some YFZ shocks before i bought some no name jump offs Quote Link to comment Share on other sites More sharing options...
UPbansheeRacer Posted December 9, 2011 Author Report Share Posted December 9, 2011 yeah im looking for a set of raptor shocks with the resevoir on them when im done with school for the summer and im back to work might just get a used set of works Quote Link to comment Share on other sites More sharing options...
Dicklez Posted December 9, 2011 Report Share Posted December 9, 2011 I'd ask mattscss. Hes the shock man. He should be able to tell you if they are scrap or not but just lookin at the price and the no name i would think they are. Quote Link to comment Share on other sites More sharing options...
Azryll Posted December 9, 2011 Report Share Posted December 9, 2011 looks like chinese junk to me. They are progressive shocks just like stockers. The point of aftermarket shocks is multi-rate springs and setup for your riding style and weight so they perform right. I wouldn't waste my money on these, yfz or raptor shocks. They are not they same length so its gonna change your ride height, still using progressive spring, and not setup for you. Just save your money, buy a quality shock and you won't regret it. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted December 9, 2011 Report Share Posted December 9, 2011 looks like chinese junk to me. They are progressive shocks just like stockers. The point of aftermarket shocks is multi-rate springs and setup for your riding style and weight so they perform right. I wouldn't waste my money on these, yfz or raptor shocks. They are not they same length so its gonna change your ride height, still using progressive spring, and not setup for you. Just save your money, buy a quality shock and you won't regret it. so whats wrong with a progressive spring on a shock..... Quote Link to comment Share on other sites More sharing options...
Azryll Posted December 9, 2011 Report Share Posted December 9, 2011 so whats wrong with a progressive spring on a shock..... Most progressive springs are pretty generic. We do not all weigh, ride, or drive on the same terrain. With a multi-rate (two or more linear springs) each spring is picked for your needs, plus you can adjust the initial rate, the transition between springs, and the final rate. You can get a almost limitless setup thats custom tailored for you. They offer a softer initial compression while allowing you to decide when the cross over point is, giving a smoother ride. Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted December 9, 2011 Report Share Posted December 9, 2011 The spring rate doesn't make those junk, the shocks as a whole make them junk! You get what you pay for. Alot of MX guys run single rate springs. If valved and setup correctly, a single rate would be fine. Not these shocks though, these are cheap china junk. Quote Link to comment Share on other sites More sharing options...
Azryll Posted December 9, 2011 Report Share Posted December 9, 2011 It definitely comes down to more than just the spring, internals are a factor as well. I was just pointing some of the flaws out besides being a crappy shock in general. Why would alot of MX guys use a single rate spring? You would lose so much adjustment especially going from track to track. Even the level entry Elka stage 1 are dual rate and pretty much any quality aftermarket shock on the market. With a single rate all you can't adjust is preload on the spring (not talking about valving- compression and rebound). You would have to have a ton of extra springs laying around. With multi rate you can adjust this with a wrench to dial them in. Hopefully Matt chimes in cause he will know tons more than me Quote Link to comment Share on other sites More sharing options...
donkeypuncher Posted December 9, 2011 Report Share Posted December 9, 2011 Those shocks have been asked about on here quite a few times. Theyre chinese junk. Matt will say the same. If you're on a budget pick up a set of works shocks or used non reservoired Elkas (set up for you). Quote Link to comment Share on other sites More sharing options...
