chris c Posted December 8, 2011 Report Share Posted December 8, 2011 Someone probably asked this already. But does anyone uses the swingarm, rear shock and linkage on the banshee. I've seen threads where they can mount the swingarm but didn't see if they use the linkage and shock off a yfz. Has anyone tried it cuz my body is giving me his rear shock n linkage just need the swingarm or can I mount it on a aftermarket swingarm. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted December 9, 2011 Report Share Posted December 9, 2011 Someone probably asked this already. But does anyone uses the swingarm, rear shock and linkage on the banshee. I've seen threads where they can mount the swingarm but didn't see if they use the linkage and shock off a yfz. Has anyone tried it cuz my body is giving me his rear shock n linkage just need the swingarm or can I mount it on a aftermarket swingarm. There really is no purpose to using any of the 450 rear suspension. The stock banshee shock is almost identical internally as far as valving and piston design. Quote Link to comment Share on other sites More sharing options...
chris c Posted December 10, 2011 Author Report Share Posted December 10, 2011 I kinda want 2 set it up 2 use the same suspension as the yfz. I want 2 update my banshee a lil. But want 2 start off using stock yfz parts. I need the rear hubs n axle. Bent my swing arm but a buddy of mine is selling me his stock swingarm n shock off his 05 yfz. I have the front arms n shocks. My buddy is selling me some of his stock stuff but just wondering if the stuff fits on it so I don't have 2 order the parts since my buddy is selling the stuff 2 me cheap. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted December 10, 2011 Report Share Posted December 10, 2011 I understand where you are going with this, but I think you're going about it the wrong way. The simple answer is, no. None of the suspension components off of the YFZ will fit on the Banshee frame without modification, especially the rear suspension. The 450 rear swingarm uses a completely different style pivot tube, and if I'm not mistaken, the chain alignment is about 5/8" off. Simply replacing your rear swingarm, and shock with parts off of an 05 YFZ isn't really "updating" anything. It's more of putting different shaped parts on there, doing the exact same thing. The technology used in the YFZ450 shock is identical to the technology used in the first shock used on the banshee in 1987. Nothing has changed. Not the seal head design, piston design, valving design, etc. Nothing. I've pretty much made my argument against using yfz450 suspension on Banshees, so I won't repeat myself, other than to say it's not a great idea, and I have seen very few actually work. The reason I'm telling you to not even attempt, is because this has been tried, and failed at, thousands of times. I get phone calls every day from people trying to make the stuff work, and they end up just throwing it away and buying the proper stuff. IF you get it to work, it will still be substantially sub-par to even the bottom of the line aftermarket equipment available for the Banshee. Again, I cannot stress enough: Don't cobble together a bike. I personally don't feel that it is safe, nor cost effective in the long run. None of the components are "bolt on", and everything will require modification to some degree. Quote Link to comment Share on other sites More sharing options...
