camatv Posted December 13, 2011 Report Share Posted December 13, 2011 wow,. Quote Link to comment Share on other sites More sharing options...
gotnos Posted December 14, 2011 Report Share Posted December 14, 2011 Had the same style motor just put on alky with 40mm carbs runs a hell of a lot better didn't think was possible with vitos LOL but purging doesn't tke long and u should u the guzzle cause it sucks a lot of gas and domes should be 17cc Quote Link to comment Share on other sites More sharing options...
EvilBanshee Posted December 14, 2011 Author Report Share Posted December 14, 2011 Had the same style motor just put on alky with 40mm carbs runs a hell of a lot better didn't think was possible with vitos LOL but purging doesn't tke long and u should u the guzzle cause it sucks a lot of gas and domes should be 17cc What do you have to do to "purge"? Also what pipes are you running? And what do you mix your oil ratio at with alcohol? Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted December 14, 2011 Report Share Posted December 14, 2011 What do you have to do to "purge"? Also what pipes are you running? And what do you mix your oil ratio at with alcohol? purging is just running the bike on gas/oil mix before you put it away for the day. it gets run until the alky has been run out and the gas/oil is firing the engine. NOT by shuting the alki off and running the bike out of fuel and THEN running it on gas....that will be a sure way to burn up your motor. Quote Link to comment Share on other sites More sharing options...
EvilBanshee Posted December 14, 2011 Author Report Share Posted December 14, 2011 (edited) purging is just running the bike on gas/oil mix before you put it away for the day. it gets run until the alky has been run out and the gas/oil is firing the engine. NOT by shuting the alki off and running the bike out of fuel and THEN running it on gas....that will be a sure way to burn up your motor. SO i have to either run the whole tank of alcohol up, then add mixed Gasoline, run it for a few minutes,then i can leave the bike over night? What kind of octane is needed to run a big bore on 17cc domes?..... the highest i can get that i know of is 112. Edited December 14, 2011 by EvilBanshee Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted December 15, 2011 Report Share Posted December 15, 2011 haha....no no......alot of guys will just shut off the fuel valves on the tanks and just pull the fuel lines off and hook it to a small "purge tank" that has hookups for the fuel lines on it......just a tiny little tank that you can put a little gas/oil mix in. You do not have to burn the entire tank in order to purge. Quote Link to comment Share on other sites More sharing options...
tedd1 Posted December 15, 2011 Report Share Posted December 15, 2011 I usually don't purge until I am done for the weekend... Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted December 16, 2011 Report Share Posted December 16, 2011 my purge tank is an old overflow bottle,if your riding in temps around 40deg dont bother converting,also alky is the best for power increase i love it Quote Link to comment Share on other sites More sharing options...
