Trans oil
brock42
ATF, anything more is a waste of money.
it works in way higher HP cars with autos and manuals, so its good enough for a cycle trans
everyone has their preference, but it just makes them feel better spending more to do the same thing
many many years in same bike with ATF and NEVER a gear or clutch failure problem, EVER....normal wear
i used to run atf type of and recently switched to spectro 10w-30 and it shifts waaaaayyy better, wish id been using this instead of the atf that id used for years. also atf needs changed alot more often $.02
Like stated above, I have ran it all over the years- Most is over priced
Alot of builders recommend ATF so thats what i run- Ive been running it for years with NO issues at all.
I have 2 HARD HARD seasons on a fast clutch and its still perfect- I change my oil every 3-4 rides. Its cheap enough, no reason not to..
JMO
Joe
