txbanshee513 Posted January 10, 2012 Report Posted January 10, 2012 I'd love to get a 4mil 75mm bore small block. i have a 75 4mm set up and love it. just finally got it ported on meth, been running on gas non ported. was actually told by Lewie, if you dont want to port it you would be better off with a 68 because of the cnc port design. Quote
585 twister Posted January 12, 2012 Report Posted January 12, 2012 i have a 10mil. 76.5 big block on alky. i run the hell out of it.it just keeps going.buddy has a535 10mil. cheeta and has problems all the time with it. Quote
lms1977 Posted January 12, 2012 Report Posted January 12, 2012 i have a 10mil. 76.5 big block on alky. i run the hell out of it.it just keeps going.buddy has a535 10mil. cheeta and has problems all the time with it. what kind of problems does he have with it?? why is the twister better Quote
585 twister Posted January 13, 2012 Report Posted January 13, 2012 what kind of problems does he have with it?? why is the twister better he had problems with the niklesil coatings, head studs pulling threads, cylinder studs brakeing,melt downs.hes detuned it alot and its holding together now..it was set up when he bought it but spent alot getting it right..the twister has a boreable sleeves and u can go bigger cheaper. usualy if u stick a piston u can just rehone it and slap new pistons in it and the pistons can be bought over the counter. where his can usaully screw up the nicesil and has to send the cylinder off to get fixed and has to order pistons. ive have both styles of cylinders on a few things. it just can get real spendy haveing one set up wrong Quote
