wildcatfa0309 Posted December 5, 2011 Report Share Posted December 5, 2011 (edited) i traded for this banshee a few weeks ago its a 2001 model looks to be stock it has the stock pipes on it i do know that the guy said it run great and that it had sit for a while and atmost needed the carbs cleaned when i got it home i checked the fire and it wasnt firing and i just quit fooling with it and sold it to a guy cheap he got it firing by cutting the wires to some kinda fuel emergency cut off switch or something like that was what he called it it was two wires that went in to the thumb throttle on the right side handle bars so when he got it firing he cleaned the carbs and said it would run but it was rough he said he took the mag cover off and said there was water in it he sanded the mag just to clean it up and it helped the way it ran now to where im at on it.... the guy ended up not being able to pay for it and brung it back to me it starts extreamly easy and idles just great as far as its peformance its really lacking power its weird though because it is real sluggish when it takes off , ya kinda have to feather the clutch and throttle to get it going then when your rolling you can bring it to the power band in 1st gear and just braaap it and the front wheels will leave the ground but it dont act like it has enough power to keep the wheels off the ground just like it has full power right it the braap but thats it it sounds like its making all kinds of power but it just aint at all it just hasnt got that drag you off the seat power that banshees have it sounds good allthough the left side exhaust has a lil stronger sound than the right side exhaust and actually it has about as much power as just one side of the engine would probally make hope this isnt to confusing i guess what im saying if somebody had never rode a banshee they would probally think theres nothing wrong with the bike but i have rode banshees and this one is weak it runs about half as good as it should anybody know where i should start at thank you so much for your help oh yeah and one more thing when in neutral and when you rev it up it aint got that fast braaaping throttle responce it kinda starts a lil sluggish when you first rev it but once its in the band range it revs right i know it has problems just dont know where to start Edited December 5, 2011 by wildcatfa0309 Quote Link to comment Share on other sites More sharing options...
ap3x Posted December 5, 2011 Report Share Posted December 5, 2011 First thing I would do is check the compression. Quote Link to comment Share on other sites More sharing options...
thomas h. Posted December 5, 2011 Report Share Posted December 5, 2011 I would compression check blow out carbs new plugs b8es with brand new 5k caps. Check the stator gap. Leak down test to find air leaks. If that doesnt catch it post update. For step two. Quote Link to comment Share on other sites More sharing options...
