David DeLeon Posted December 2, 2011 Report Share Posted December 2, 2011 I have two banshees and both are set up very similar set up. Stock cylinders, aftermarket reeds, FMF Gold Series pipes, stock air box with snorkle removed. I run 290 Jets. Carbs are sync correctly. They have TORS removed. Aftermarket idle screws set up. I can not get the motor to idle. If I adjust the throttle cable it will idle, but I can not get it to idle without tightening the cables. The idle screws are all the way in. I have checked the small jet and it is clear. Should I put a larger idle jet in? Or am I missing something. Thanks in advance. David Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted December 2, 2011 Report Share Posted December 2, 2011 Put in 27.5 pilots. It's usually required, whenever you put on aftermarket pipes. Quote Link to comment Share on other sites More sharing options...
knelson Posted December 2, 2011 Report Share Posted December 2, 2011 (edited) file down the thread boss on your idle screw boss. sounds like your screws arent hitting the slides raising them Edited December 2, 2011 by knelson Quote Link to comment Share on other sites More sharing options...
lms1977 Posted December 2, 2011 Report Share Posted December 2, 2011 file down the thread boss on your idle screw boss. sounds like your screws arent hitting the slides raising them I would bet this is your problem Quote Link to comment Share on other sites More sharing options...
