FraireRacing Posted November 26, 2011 Report Share Posted November 26, 2011 I have a stock 64mm pistons still Cherry lol. I ported the cylinders from intake and exhaust only. I have a cool head that im about to run w/ 18cc domes I had 22cc domes before. I have boyesen reeds and cages, 1/2in carb spacers, an aluminum Y w/18cc a single 39mm kehien carb with a k&n, and t5 exhaust. I also have a Ricky stator and an adjustable timing plate. My question is am I going to have to run race gas or can I still get away w/ using 93 octane and an octane booster Quote Link to comment Share on other sites More sharing options...
wesw Posted November 26, 2011 Report Share Posted November 26, 2011 Search feature works great Quote Link to comment Share on other sites More sharing options...
Infamous039 Posted November 26, 2011 Report Share Posted November 26, 2011 DO NOT put octane booster in your bike. When you install the 18cc domes you need to compression test your motor and that will tell you what type of fuel you will need to run. Just remember anything over 165-170lbs, requires higher octane fuel. Quote Link to comment Share on other sites More sharing options...
FraireRacing Posted November 26, 2011 Author Report Share Posted November 26, 2011 Octane boosters aren't good for Banshee's? I haven't tried it but I was just thinking about it. And thanks man I didn't know what the compression limit had to be to run pump or race fuel Quote Link to comment Share on other sites More sharing options...
dajogejr Posted December 12, 2011 Report Share Posted December 12, 2011 I know this is old...but you need to measure compression ratio, not cranking compression. You get cranking compression by using a PSI gauge in the cylinder. You get compression ratio by measure parts/clearances/tolerances inside the motor. Cylinder volume and trapped head volume are just a few of the numbers you'll need. I agree, this has been covered a lot, and it's easier to search the forum and Google for it rather than any of us rewrite a novel!! Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted December 13, 2011 Report Share Posted December 13, 2011 you timing needs consideration too. Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted December 13, 2011 Report Share Posted December 13, 2011 Octane boosters aren't good for Banshee's? I haven't tried it but I was just thinking about it. And thanks man I didn't know what the compression limit had to be to run pump or race fuel I dont think it that there not good but that they dont really work. They only slightly move the octain up. I believe. Quote Link to comment Share on other sites More sharing options...
FraireRacing Posted December 15, 2011 Author Report Share Posted December 15, 2011 But will they affect the bike at all Quote Link to comment Share on other sites More sharing options...
dajogejr Posted December 15, 2011 Report Share Posted December 15, 2011 I'd use octane boosters in an absolute pinch if I had too, otherwise, hell no. Octane boosters are good for a point or two, and you'd have to use quite a bit to be honest. Toulene is a common compound used in octane boosters, as well. It is NOT what you want for a high revving two stroke motor. Buy race fuel, again...if you need it based on compression ratio, not cranking compression. Quote Link to comment Share on other sites More sharing options...
FraireRacing Posted December 16, 2011 Author Report Share Posted December 16, 2011 Thanks I really appreciat it guys!!!!! Quote Link to comment Share on other sites More sharing options...
registered user Posted February 1, 2012 Report Share Posted February 1, 2012 (edited) I know this is old...but you need to measure compression ratio, not cranking compression. You get cranking compression by using a PSI gauge in the cylinder. ya what he said this puts it in lamens terms http://www.2strokeheads.com/tech2.htm Edited February 1, 2012 by registered user Quote Link to comment Share on other sites More sharing options...
