Thack82 Posted January 14, 2016 Report Share Posted January 14, 2016 I'm posting this for future Banshee Owner's looking for information on this topic and wanting to upgrade the OEM Banshee Foot Peg's using the Stock YFZ-450R/X Race Peg's. Answer: Yes, the 2009+ YFZR-450R/X Pegs will fit the Banshee with very minimal modification. You need to cut or grind a spacer off the back of the peg on the PTO (Clutch) slide. Then you need to take a small carbide bit and slot all four holes 3mm on the YFZR/X Peg's and that's it...... Other than one fine thread foot peg bolt that is a little longer. I pasted a tool list thats required to complete the foot peg swap successfully bellow: - Take Off YFZ-450R/X Racing Foot Pegs. - Four Inch Grinder w/ 80g Sanding Wheel. - One Longer Foot Peg Bolt For Right Side Peg. - Pneumatic Die Grinder w/ Small Carbide Porting Bit. - 15mm Open Box End Wrench - Can Of Brake Cleaner & Anti-Sieze for the foot peg mounting hardware. Quote Link to comment Share on other sites More sharing options...
monster Posted January 16, 2016 Report Share Posted January 16, 2016 IMS Rapper 660 pegs bolted on with just a spacer on right side and had to cut shifter pivot off left side. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted January 16, 2016 Report Share Posted January 16, 2016 I've been rockin those for quite a while. Zero modification needed to shifter side and only a 12mm long spacer with a 1/2" hole and a 12mm longer screw on brake side. Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted January 24, 2016 Report Share Posted January 24, 2016 neat Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted January 24, 2016 Report Share Posted January 24, 2016 Good job! Quote Link to comment Share on other sites More sharing options...
mailman Posted September 3, 2017 Report Share Posted September 3, 2017 Bump for a good topic. I just put the '09 YFZ pegs on my Shee. They are so much nicer than the stock pegs. Quote Link to comment Share on other sites More sharing options...
