advice on welded ball
oprahwinfree
Around 4 months ago i welded the ball in my transmisson shortly after football started so i had little time to work on the shee. So far ive takin the clutch and everything off the motor i was just looking for some advice on how to fix it, i was also looking in to getting a serval seeing as i allready have a 4 mill crank but dont know who much of a improvement it would be between a ported 4 milll pods andvanced timing and t5's.
-thanks in advance
depending on how bad it is it will range from fishing it out with a magnet to replacing the transmission shaft that it rides in. i have one here that someone hosed it bad enough the push rod is permanently welded inside the shaft. Either dont coast with the clutch pulled in or go to a pancake bearing setup.
yeah its in there for good in I was pretty sure that splitting the case was in order. once i get to the transmission do you think ill be able to use a punch to get it out or will i need to find a new transmission. also i was trying to get the clutch arm out of the case and it seems to be stuck. I was following the manual's instructions but i was thinking i was getting cought up on the rod?
new shaft is less than $80 from bikebandit.com
I've got 2 tranny shafts in the garage with permanent welded parts on them. Beat one of them with a 4 lb sledge and couldn't get the fucker out. I bought tranny shafts from members on here for less than $20. Might post in the wanted section
Sandfrk, can you please post a pic of those tranny shafts? I had the same thing happen to me but i was able to get the pancake bearing out. The ball bearing is welded to the adjuster. Also, do you have any other advise on taking the rod out? When i stick a magnet in there i can move it a little bit but it won't come out. I think it welded itself to the clutch arm, because i can wiggle the arm and it moves the rod. I would hate to tear into a perfectly running shee. Ayways, Thanks for your guys' help!!
  • 1 month later...
Guys any help on this welded rod situation? I would hate to start a new thread on this. The adjuster and the ball bearing came out, but i can't get the rod out. Anybody have any ideas on how i can get this rod out without splitting the cases? Thanks for all your help.
You are going to have to split the cases, it sounds like the pushrod welded to the clutch arm. If that is the problem, the shaft will stay with the upper case when it comes apart, and yes it can be split with the arm still in the case. When you get it fixed you can either put in a pancake bearing OR switch to Klotz Flex Drive 30 tranny oil. I have ran this in all my Banshees and Blasters includung the wife's and kid's bikes for about 20 years now. We have NEVER lost a gear, bearing, clutch, or welded a clutch ball with it, even on the girl's bikes that the coast and idle with the clutch lever pulled in. NONE of our bikes have pancake bearings. It isn't cheap, but you get what you pay for.
