2004LEBanshee Posted September 6, 2003 Report Posted September 6, 2003 I have a completely stock banshee and people have said I could remove the snorkle and not have to jet it is this true or not? Quote
reas11 Posted September 6, 2003 Report Posted September 6, 2003 if u remove the snorkel u have to rejet .. Quote
2004LEBanshee Posted September 6, 2003 Author Report Posted September 6, 2003 never jetted what should I jet to 3 weeks old dont want to screw it up Quote
reas11 Posted September 6, 2003 Report Posted September 6, 2003 start high go 3 sets higher than u are at and then go lower its pretty simple not to screw it up ..get a clymers it will do u some good just gotta remember dont get scared everyone was in the same boat as u at one point in there lives.. the hq is full of info .. just look and u shall find .. Quote
2004LEBanshee Posted September 6, 2003 Author Report Posted September 6, 2003 can i check my spark plug after idleing because there is nowhere for me to ride around my house Quote
jcanapa Posted September 6, 2003 Report Posted September 6, 2003 IT DOESNT DO ANY GOOD TO CHECK THEM AT IDLE. yOU NEED TO READ YOUR PLUGS AT WOT KILL, 6TH GEAR IS THE BEST. FIND A PLACE TO RUN WOT THEN KILL IT WHILE WOT. TAKE YOUE 13/16 WRENCH OUT OF YOUE POCKET AND PULL THE PLUGS. DOING A PLUG CHOP IS TRUELY THE BEST WAY TO GET A CORRECT READING. OR TOSE A A OLD SET AND TAKE THEM BACK TO YOUR GARAGE TO LOOK AT THEM. LIKE REAS11 SAID, WE WHERE ALL THERE AT ONE TIME. GOOD LUCK AND GIVER HELL! Quote
brokemybanshee Posted September 7, 2003 Report Posted September 7, 2003 Shit man, its getting to the point where if I don't take it apart I get scared :twisted: Quote
9603banshee Posted September 7, 2003 Report Posted September 7, 2003 If you take your snorkel off, go two sizes bigger on mains, and you'll automatically in a safe zone. Example-200 mains are on most stock bikes out of factory, put 220's in and you're good. Quote
brandon87 Posted October 20, 2003 Report Posted October 20, 2003 you might not need to rejet I have no snorkel the rest stock and 180 mains 700-ft above sea level air screws 2 1/4 turns out (started at 1.5 turns out) I tried going to 210 mains and it was way too rich but i run a synthetic oil at 42:1 FIND BENBB AND GET HIS (JETTING FAQ) OFF OF HIM. His 30-40 question Q&A is the best thing to have when jetting you should go to a synthetic pre mix if you are not already using one that will richen your mixture anyway Quote
