LIMTED EDISH Posted November 15, 2011 Report Share Posted November 15, 2011 So i have a banshee that i built to the gills nothing but the frame and plastics are stock i really need help cause i am getting 0 spark so would someone help me out please Quote Link to comment Share on other sites More sharing options...
ginger Posted November 15, 2011 Report Share Posted November 15, 2011 easiest way, if you still have your stock stuff try one piece at a time, try the stock coil, if that doesnt fix it, then try the stock CDI, if that doesnt then stator, ECT. Quote Link to comment Share on other sites More sharing options...
thomas h. Posted November 15, 2011 Report Share Posted November 15, 2011 A wiggle test helped me out turned out to be the cdi connector. Have some one kick it and watch the spark tester. Mean while you wiggle the wiring harness. Quote Link to comment Share on other sites More sharing options...
csbullrider92 Posted November 16, 2011 Report Share Posted November 16, 2011 Check your killswitch and key assembly Quote Link to comment Share on other sites More sharing options...
AKheathen Posted November 16, 2011 Report Share Posted November 16, 2011 decscribe "built to the guild" as for as you electronics/wiring goes. what have you done? without knowing that all i can tell you is to start ohming your stator and coil, and chack your pickup gap on both sides of the flywheel. the last thing is to unplug your cdi and take the following readings of the harness- black to black/white- should be open, no continuity with the killswitch in run. black to black/red- should be closed (about 0 ohms) with the key on and then your stator readings can be first measured there. if you get a bad reading, go right to the stator. black to frame, engine bare metal, and coil mounting/black wire. Quote Link to comment Share on other sites More sharing options...
