From Mild TO Wild! Posted November 12, 2011 Report Share Posted November 12, 2011 Is there a HP difference or is it just when the power band comes on difference? Quote Link to comment Share on other sites More sharing options...
Smokestack Posted November 13, 2011 Report Share Posted November 13, 2011 Been looking into this myself. I will need new ones soon. But still lost on what the differences are Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted November 15, 2011 Report Share Posted November 15, 2011 Single stage reeds are like the stock ones. They are just once pice petals. Dual stage reeds have a set of petals on top of another set of petals. That way at lower rpms the top lighter tension set is the one doing the majoirty of the work. Then when you open it up the stiffer bottom set opens up. There are windows cut in the bottom set and the top set seals them up. Then you have v forces. They cram 2x as many single stage reeds. They operate on the basis 2x as many reeds opening half as far. So they have less travel time from closed to open to closed. Quote Link to comment Share on other sites More sharing options...
