bansheemandan Posted November 8, 2011 Report Share Posted November 8, 2011 $3800 or trade for a 2006 and up yfz450 2001 banshee, with title, the quad was just built from the ground up and only has 2 hours ride time since it was finished, it is very fast, i just want to try out a 4-stroke chassis --- (again everything on the banshee only has 2 hours ride time) powder coated frame-a-arms-front and rear hubs-swingarm-steering stem-spindles-foot pegs-rear brake pedal extended lonestar a-arms extended durablue axle// the axle is adjustable and you can make it wider rear shock rebuilt and revalved by RRP yfz front shocks rebuilt by RRP every bearing and bushing in the chassis is new new chain and sprockets new front and rear brakes new rear brake caliper rear stainless steel brake line renthal handle bars new rear tires//gbc gators new front tires//razr's RAD dual bearing billet aluminum axle carrier PRM front bumper PRM rear bumper PRM swing arm skid plate PRM chassis skid plate polished alum. master cylinder cover polished alum. throttle cover polished alum. handle bar clamp/ key holder new throttle and clutch cables like new yellow plastics carbon fiber hood/radiator cover shock covers headlight covers black and yellow gripper seat cover IMS oversized gas tank i am sure there is some stuff that i forgot about engine (again only 2 hours of ride time) completly rebuilt bottom and top end 4 millimeter stroker crank with tz bearings/trued and welded HERR JUGGS RACING ported cylinders HERR JUGGS RACING cut stroker domes PRO DESIGN cool head WISECO pistons and rings CHAROLET reed cages and carbon fiber reeds KEIHIN 28mm pwk carbs K&N air filter with outerwears cover WISECO clutch basket BARRNET clutch TOOMEY t-5 pipes and silancers PRO DESIGN high flow water pump impeller all new seals and gaskets throughout engine PRO DESIGN timing plate Quote Link to comment Share on other sites More sharing options...
Rustynail Posted November 8, 2011 Report Share Posted November 8, 2011 Still rocking the gold wheels!!! Quote Link to comment Share on other sites More sharing options...
