miami350 Posted November 2, 2011 Report Share Posted November 2, 2011 i just some pwk 35mm carbs bear with no needle and jets what needle should i get and jets .. my bike only has cpi pipe and a timinng plate.... but other then that the bike stock. So tell what jets and needle to run .. im in miami,FL Quote Link to comment Share on other sites More sharing options...
gotta_goatsfast Posted November 2, 2011 Report Share Posted November 2, 2011 Dude 35mm PWKs are HUGE for your setup. I wouldn't even know where to start. In order for it to run proper on the top end you'll be burbling and mushy in the low-midrange. I suggest running something smaller like 28 PWKs. Quote Link to comment Share on other sites More sharing options...
miami350 Posted November 3, 2011 Author Report Share Posted November 3, 2011 Just found out my piston are 66.25mm so i need to know the jetting to run Quote Link to comment Share on other sites More sharing options...
powervalve400 Posted November 4, 2011 Report Share Posted November 4, 2011 Just found out my piston are 66.25mm so i need to know the jetting to run Try starting with 6.0 slides, cel needles in the 3rd clip from the top. 50 to 52 pilots and 158 mains. Should get you in the ball park. Very important make sure you are getting full throttle. Quote Link to comment Share on other sites More sharing options...
