Rauls17 Posted October 31, 2011 Report Share Posted October 31, 2011 My springs are fading and I wanted to see if you guys could tell me where I can get new springs and how to put them on and if I can do that my self or I need to have a professional do it thanks in advance Quote Link to comment Share on other sites More sharing options...
Coupelx Posted October 31, 2011 Report Share Posted October 31, 2011 Its probably not the springs but the shock itself that is shot. sounds like a good time to find some aftermarket ones. Quote Link to comment Share on other sites More sharing options...
Infamous039 Posted October 31, 2011 Report Share Posted October 31, 2011 I have a set of stocks shocks if you want them for cheap ?? Quote Link to comment Share on other sites More sharing options...
Rauls17 Posted October 31, 2011 Author Report Share Posted October 31, 2011 Na they work perfect I just wanna replace my springs cause there ugly but they work perfect were could I buy springs Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted November 1, 2011 Report Share Posted November 1, 2011 You will not be able to purchase aftermarket springs for the stock shocks. Removing them without a proper spring compressor is probably one of the most dangerous things you can do on a Banshee. If you want to paint the springs, slide some paper up behind the spring to protect the shock body and shaft; tape off everything you don't want paint on; and rattle can the shit out of them. 'Bout your only option without having someone remove the springs for you. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted November 1, 2011 Report Share Posted November 1, 2011 You will not be able to purchase aftermarket springs for the stock shocks. Removing them without a proper spring compressor is probably one of the most dangerous things you can do on a Banshee. If you want to paint the springs, slide some paper up behind the spring to protect the shock body and shaft; tape off everything you don't want paint on; and rattle can the shit out of them. 'Bout your only option without having someone remove the springs for you. I built one of dem Adaptor Kits for that there shop press. Quote Link to comment Share on other sites More sharing options...
Rauls17 Posted November 1, 2011 Author Report Share Posted November 1, 2011 You will not be able to purchase aftermarket springs for the stock shocks. Removing them without a proper spring compressor is probably one of the most dangerous things you can do on a Banshee. If you want to paint the springs, slide some paper up behind the spring to protect the shock body and shaft; tape off everything you don't want paint on; and rattle can the shit out of them. 'Bout your only option without having someone remove the springs for you. that's exactly what AMA do Quote Link to comment Share on other sites More sharing options...
Overboost Posted November 13, 2011 Report Share Posted November 13, 2011 shock covers, shock covers, SHOCK COVERS Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted November 14, 2011 Report Share Posted November 14, 2011 shock covers, shock covers, SHOCK COVERS Shock covers generally cause more damage then good. They trap moisture, dirt, and other debris inside the shocks. I do not recommend anyone run them, and also do not warranty any of my work, should the customer decide to run shock covers. They were an idea based off of a design for offroad/racing shocks, to keep rocks from pitting the shaft. They were a semi-rigid cloth sleeve, that was open at the top and the bottom, and JUST covered the portion of the spring where the shaft was exposed. Somehow the ATV market completely missed the mark with this idea and decided that enclosing the shock completely was a good idea... I'm not knocking anyone for running shock covers, but just realize that you may be doing more harm than good by running them. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted November 14, 2011 Report Share Posted November 14, 2011 Yep, those a tually serve the proper purpose, and work well. Just not the Velcro/elastic fabric ones. Quote Link to comment Share on other sites More sharing options...
jayzx10r Posted November 18, 2011 Report Share Posted November 18, 2011 Shock covers generally cause more damage then good. They trap moisture, dirt, and other debris inside the shocks. I do not recommend anyone run them, and also do not warranty any of my work, should the customer decide to run shock covers. They were an idea based off of a design for offroad/racing shocks, to keep rocks from pitting the shaft. They were a semi-rigid cloth sleeve, that was open at the top and the bottom, and JUST covered the portion of the spring where the shaft was exposed. Somehow the ATV market completely missed the mark with this idea and decided that enclosing the shock completely was a good idea... I'm not knocking anyone for running shock covers, but just realize that you may be doing more harm than good by running them. What about in the sand? Every dirt bike I took out to the sand started pissing oil at the rear shock so I bought covers for my Banshee. Are you saying that it would be better for my Axis shocks to take the covers off? Quote Link to comment Share on other sites More sharing options...
duramaxsmoke Posted January 2, 2012 Report Share Posted January 2, 2012 i like those carbon covers pretty expensive or what Quote Link to comment Share on other sites More sharing options...
