Do Fly Wheels go Bad?
SonOfSand
The compression of the motor will hold it.
Like said above buy some water based lapping compound. Put a little on the cranck taper. Then just twist the flywheel back and fourth. Make sure not to get any in the crank seal. Then just clean it all up. The water base cleans up better than the grease base lapping compound.
