Best gasket sealant to prevent air leaks
thomas h.
If your an engine builder please mention it but I'd like to get the best sealant method to use for my engine. Thanks
I use Permatex Moto Gasket Grey works good and it is not impossible to clean off if you need to rebuild. It does set up fairly fast so you need to be ready when you put it on.
Good stuff guys thanks I'll be watching to see if their is any other input.
On the cases, I prefer Yamabond 4. On my gaskets I always use OEM gaskets and put them on dry. I have never had a problem with leaks doing it this way. As was mentioned, it is more important to have good clean, smooth, flat sufaces. By installing the gaskets dry, you stand a chance of reusing it if you have to pull something on the trail.
good call, didnt think he was talking bout gaskets until i read the title again. i always put gaskets on dry. as mentioned, as long as your mating surfaces are clean and smooth, shouldn't have a leak.
