I got my Serval back in March. My mods are listed in my sig. The only difference was the pipes. When I got it I did not want to spend money on another set of pipes so I just stuck with my t-5's and it ran very well but it was not as significant of an upgrade from my dune ported 350 as I would have liked. At the time I was actually regretting getting the serval and thinking that I should have got a cub. Over the summer I ended up breaking down and buying a set of cpi's and going with what other people seem to be running on the Serval. The power increase was very significant. The t-5's seemed to have just a mediocre mid to high end power but the cpi's really seemed to wake it up from late mid range to high. After switching to the cpi's I now really enjoy this motor and would suggest it to anyone that is looking for a dune motor that also like to drag for fun.
good right up!! how much if any did it affect you bottom end power?
I would say that bottom to mid range was for the most part an unnoticeable change between the two sets of pipes but it was a big change from the dune ported 350 to the serval.
Hopefully the shearers I get make a big difference! Im going from totally stock yo serval 35mm carbs shearers. So im sure I could tell..haha
I did a 421 serval on my bike (now my wifes) and went from t5's to Shearers..the T5's were holding it back seriously compared to the Shearers. You'll be pleased with your choice.
did you notice any difference in bottom and midrange?
I did not have T-5, I had DMC aliens which are not much different than T-5's on a set of vitos 421 cylinders.With 30mm carbs and DMC pipes,it made 55hp
I bolted on a set of CPI inframes and 34.5 PJ carbs with a full airbox and K&N powerlid.The engine made just under 80hp and probably would have made more with shearers considering the 200 degree exh port duration .Some pipes just won't work on the big bore stroker engines.
guys I'm starting my build this month probably next week i will buy the suspension and tires etc... so i was wondering what will i be best off with Serval dune ported and 35pwk on Sheerers or CPIs? also should i use Hanson full clutch parts or lock up ? will i need a cool head for the bike and a larger radiator ? :confused:
Try some r2 pipes, haven't heard a bad thing about them!
