sp1tekiller Posted October 20, 2011 Report Share Posted October 20, 2011 No idea why. Just acts like 3rd is the top gear. Bottom 3 all work fine. Finding neutral doesn't seem to be too much of a chore, either. Quote Link to comment Share on other sites More sharing options...
jlsparky7 Posted October 20, 2011 Report Share Posted October 20, 2011 Do you have a magnetic drain plug? Sometimes the magnet comes loose and sticks in the shift drum.... Other possibilities would be a bent or broken shift fork.... Quote Link to comment Share on other sites More sharing options...
jlsparky7 Posted October 20, 2011 Report Share Posted October 20, 2011 I have teardown and rebuild vids on my youtube page if you need help with the rebuild... Quote Link to comment Share on other sites More sharing options...
EZ-GO Posted October 24, 2011 Report Share Posted October 24, 2011 Take off the clutch cover and check the shifter adjuster by the shift star.. Mine came a lil loose and was acting goofy and wouldnt let me shift only second and third sometimes first.. I took off the clutch cover and adjusted it and that solved my problem.. Hope this is the problem so you dont have to tear into the engine.. Quote Link to comment Share on other sites More sharing options...
camatv Posted October 25, 2011 Report Share Posted October 25, 2011 take to cover off and check it out. if the shifter is jacked up and sideways replace it all. Quote Link to comment Share on other sites More sharing options...
